Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Why Does Alarm Keep Going Off
Guide to diagnose trouble and recommended solutions.
Alarm goes off when opening with key
#11
alarm goes off when opening with key
No. I thought I had found a solution but the next time I tried it the alarm went off. The solution was to unlock the door with the key then lock it then unlock it then open the door.
This problem has just shown up recently. I have had the Suburban for 8 years. I had removed the drivers side door panel to work on the speaker a few weeks before. Maybe a wire got broken. I haven't removed the door panel to check.
The one person before you said that this is normal but I don't think so. I looked at the manual and it says that you can use the FOB or the key to open the door without the alarm going off.
I would appreciate your comments.
Thanks.
Thanks.
#12
I have the same problem which just started a few days ago - alarm goes off when door either dvr or pass door unlocked with key, if unlocked with fob the alarm does not go off. I believe the fix you used turns off the alarm, I want to keep the alarm operational.
Does anyone know what could be causing this?
I have tried resetting the alarm, disconnect the battery, and change the door lock settings with no effect.
#13
problem went away
I ended up removing the door panel to work on the speaker again. When I put everything back together the problem when away. I can open the doors using only a key without the alarm going off. I would remove the door panels and make sure all the wiring and connectors look good.
sween22
Silverado & Fullsize Pick-ups
February 10th, 2020 3:25 PM
knarva
April 13th, 2013 7:23 AM
