Bad Switch?
Bad Switch?
I've got a 1997 Lumina Sedan with nearly 120,000 mis. on it and the heating ducts are stuck on window defrost. I can't change the air flow to the floor or vents...would this problem be in switch itself? By the way the rear defrost portion of the switch does work..Any thoughts?
Thanks SHAWNVW for the amazing diagnosis! After an indepth search under the hood, I discovered the vacuum line running through the firewall was separated at a union. Hooked it back together and everything works great now!! Great job SHAWNVW!
Chev_Hoe
January 14th, 2014 9:41 PM
