Notices
Bogging issues
Old October 4th, 2009, 7:42 PM
midnight rumbler's Avatar
Default Bogging issues
I seem to have a slight bogging issue with my '89 350. When at idle, it will sort of surge but not to the point where I can see it on the tach, I can just feel it. When I am at accelleration or highway speeds, I can sort of feel the truck bog down a little and the exhaust stinks like fuel.
I have replaced the fuel filter, changed the cap and rotor, plugs and wires and still have the issues.
I believe my Fuel pressure is adequate as there seems to be a good flow to the injectors and my vacuum at idle is 20. Idle is at 800rpm
The funny thing is there is a little bolt on the side of the TBI unit and if I remove this bolt, the truck is losing vacuum but seems to run better but idles higher. the reason I had done this is because that is where I tapped a vacuum gauge into and by removing the vacuum line, it allowed pressure to be lost but makes the truck run better. If I plug the hole with my finger while exposed, the truck will bog down again.
I recently replaced fuel lines with factory specs and filter and have since replaced the filter with another new one incase the last was faulty but I am still having this bogging issue. I have also cleaned the injectors by removal and added fuel injector cleaner.
Not sure if this is related t the issue but I can also hear a pinging sound but cannot locate the exact source. It seems to be coming from around the TBI unit but I cannot tell for sur. I am using an automotive stethoscope but cannot pin point the exact location of this noise. Sounds like a ping but is not coming from the rockers or the PCV valve
Any ideas would be great
theguy386
Express & G-Series Vans
May 8th, 2013 8:27 PM
midnight rumbler
October 10th, 2009 9:14 PM
projectmurder
October 7th, 2008 9:39 PM
smittygj
August 28th, 2008 6:49 PM
shaker
Silverado & Fullsize Pick-ups
October 29th, 2007 2:56 PM
Quick Reply: Bogging issues
