Cavalier heater problem
I replaced the bottom radiator hose on my 87 Cavalier conv. When I refilled the radiator I put the heater control on heat, and turned it on. Heat comes out fine, the only problem is now it only comes out thrugh the dash vents, or defrost. Nothing comes out by the floor now. Everything worked fine before the hose replacement. Any suggestions??? It also gurgles for a second when I start it cold. I filled the radiator itself untill it was full a few times, the recovery tank is full to the right spot.
RE: Cavalier heater problem
Replacing the lower rad hose will not affect where the air is routed inside the car. The diverter door at the heat box is not working., whether it's the control mechanism or the door itself.
The gurgling you hear is air in the cooling system. Leave the heat setting at max heat and run the car for awhile to help bleed the air.
Don't tell me.... it's a pain in the a%@ to get to the diverter door. It's been cold the past few days and I've been running the heat, but still have the gurgle. Thanx for the info.
oehq.com
March 25th, 2010 4:10 PM
davethomas
December 30th, 2008 8:33 AM
