Cigarette Lighter in 89 Chevy 1500
My cigarette lighter was working then it went. I noticed when it was working that things that the adapter ends of things that were plugged into it would get very hot. Just wondering if anyone would know why this would be and where the fuse would be located to see if that is what the problem may be????????????????
hey Brent, my 89 silv's fuse panel faces the seat, between the hood and parking break release. actually went out to make sure I wasn't imagining things when I had the dash out.
OP, check your ground wire, it could be a bad connection to the dash/firewall. Otherwise,it sounds like you may need emergency surgery.
1) Find a way thru the firewall. All you need is enough for 1 wire.
2)Run a 12 gauge wire(with a 20AMP in-line fuse) from the positive side of your battery to the cigarette lighter(replacements are available at the parts store also) The spade connectors you need are generally blue female.(2)
3)make sure you run a ground wire to a metal ground on the underside of the dash or the firewall.
Gotta have those accessories,man.(BTW, this is how the Mayo clinic does it, yeah-yeah...)
Cigrette lighter won't come out
I have 92 chevy pickup and cigarette lighter went out. I bought a new one to. Replace it with but can't get old one out. My fuses are good and so our my realys. I think I have a electrical short some where behind the dash due to face my cab light doesn't work buld I godod and lights that are suppose to come on when door ir opened don't come on either and cigarette lighter went out about same time any pointers would be big help thanks.
good luck
I bought new Cigarette lighter still won't heat up I also put test light on plug and it has no power. The light that is suppose to come on when ash tray is opened doenst have power either. Guessing I have a short some where any ideas on where this might be
quentusrex
January 6th, 2016 1:23 PM
