Notices
Cooling fan Relays on Venture van
Old August 10th, 2006, 9:54 AM
ottawaventure's Avatar
Default Cooling fan Relays on Venture van
Hi guys
I have a problem with my 97 Venture cooling fans, like they don't work! I pulled out the relays in the engine compartment to test them then found out that they can be replaced in any direction??????? Do you know if the orientation of these relays are important? and if so what is the proper orientation!
Thanks in advance.
Old August 10th, 2006, 2:02 PM
NCHEVYHEVN's Avatar
Default RE: Cooling fan Relays on Venture van
Yea they can be put in any way.
Old August 13th, 2006, 12:26 AM
kcb37's Avatar
You may want to check that because, when the temp goes up, power should go to oneside of the relay and thur, this will activate a switch in the relay, once activated it will supply power to your fan. It is like haveing a light switch for a domelight, and a second electronicly controlled switch that will control the door lights when the dome light is turned on.
I hope that made sense.
Keith Moon
November 6th, 2013 10:39 PM
echocluster
Express & G-Series Vans
March 4th, 2013 1:37 PM
jrhody
August 30th, 2012 7:52 AM
ottawaventure
August 10th, 2006 9:56 AM
Quick Reply: Cooling fan Relays on Venture van
