Notices
1996 Tahoe Sputtering
Old May 8th, 2008, 10:04 AM
96GreenMonster's Avatar
Default 1996 Tahoe Sputtering
We have a 96 Tahoe. It Sputters when it is under light throttle & is worse when it is Humid or Wet outside. My husband has put it on the scanner & the only thing it says is "Multi-Engine Misfire". We Don't know what to do to make it stop. He's done a tune up & changed the spark plugs, cleaned the screen, etc. Can someone please give us some insight?! Thank You!!
Old May 8th, 2008, 1:19 PM
Dave Tyler's Avatar
Default RE: 1996 Tahoe Sputtering
Did he change the Dist.cap & rotor? Don't use the cheap ones. Make sure to do the Fuel filter too. Good luck!!
Old May 10th, 2008, 8:32 PM
hquick's Avatar
Also..could be the CSFI spider injection unit.
Has it ever been changed?
If not...and you can afford to do so, change it for the new Multec mini injector unit. This will deffinately eliminate any future injector issues you may have.
WMfball2007
November 9th, 2010 10:57 AM
hugginporceilin69
Silverado & Fullsize Pick-ups
August 1st, 2009 11:08 PM
Rustybolt
April 28th, 2009 7:43 AM
dariverrat
June 17th, 2008 7:04 AM
zgcruiser
April 24th, 2008 8:05 AM
Quick Reply: 1996 Tahoe Sputtering
