Engine Swap
Engine Swap
What are the differences issues with replacing the engine in my 1998 GMC 305 Vortex MPFI with this one http://phoenix.craigslist.org/pts/712536014.html ? Will it accept all of the sensors wiring etc. Thanks for your help AJ
RE: Engine Swap
There shouldn't be any problems, but if it is an EFI rather than an MPFI there will be an issue and you'll need a wiring kit. My advice is to send the guy an email and ask if it is and EFI or MPFI and then take it from there.
RE: Engine Swap
I heard that the intake manifold will not bolt up is this true?
Mine is a 305 Vortec MPFI The fuel spider is under a black cover, for the longest time I thought it had 2 injectors but on closer inspection it has an injector at each intake valve.
