FUEL PUMP
FUEL PUMP
I have a 97 with a 5.7,around 87k miles.had been running fine.Today a lady ran into the back of me,no real damage she just hit the hitch.Now the fuel pump is not coming on when i turn on the ignition.is ther a saftey switch somewhere(reset) or did it just kill the fuel pump?thanks in advance for any help.
RE: FUEL PUMP
as far as i know there isnt a safety switch, but if your fuel pump doesnt work try your fuel pump relay under your hood... that when bad after i got rear-ended
RE: FUEL PUMP
took it apart today and the fuel pump was shorted out,also burnt up the harness from the sending unit and they dont offer just the harness so i had to buy another sending unit too.pump-163.00 strainer-11.00 sending unit-345.00 owning a chevy,not so priceless!!!!!!!!!
RE: FUEL PUMP
try the fuel shutof switch...I dont know if you have a car or truck but it will be in the trunk by the hinges behind the panelsor inside the kick panals in the cab
mangomanj
Express & G-Series Vans
August 17th, 2014 9:51 PM
22charlie
March 21st, 2013 9:54 AM
BRB
Silverado & Fullsize Pick-ups
December 28th, 2012 8:34 PM
hunter10220
May 18th, 2011 8:37 PM
ross_boss08
August 4th, 2008 2:41 PM
