Notices
HELP! 305 poping throught carb HELP!
Old October 10th, 2008, 2:56 PM
budsjlm's Avatar
Default HELP! 305 poping throught carb HELP!
Ive got a 85 monte carlo with with a 305 and comp controlledQJet the issue i am having is that at high rpms and under wotit bogs a little and pops throught the carb. it has ac accell coil and accell super stock wires and a cherry bomb witch conects where cat used to be.with about 3 feet of exhaust hooked on
i have so many placesi havestarted
-ignition
-checked plugs all look good less than 2 monthes old
-checked wires all on good less than 2 monthes old
- checked rotor looked good
carb
- well aint much to adjust since the pos is comp controlled
- thought it might be becuase of rear flaps not opening adjusted and no change
- made sure all electrical conections were good
-checked vacumes to carb all goood
vacume line
- was up and down them no cracks breaks or leaks
- just replace cracked weather worn and brokenabout 2 monthes ago
so things i might have missed let me know
also other ideas i think it may be are
bad cam
bad valve
bad valve spring
let me know any help would be great right now
Old October 10th, 2008, 4:34 PM
Deteoni's Avatar
Default RE: HELP! 305 poping throught carb HELP!
How many miles does the engine/carb have on it??
Old October 10th, 2008, 4:43 PM
budsjlm's Avatar
94xxx so could be 94 194 or above but the way it drives and handles and since im in minnesota and was origionall a texas car im going with 194sorry no idea if it's been rebuilt or replaced in the past
Old October 10th, 2008, 5:25 PM
Deteoni's Avatar
Backfiring thru the carb indicates the intake valve(s) aren't completely shut during combustion for whatever reason.
I doubt a wiped cam is the problem.
A bad intake valve or weak valve springs is possible too. They could be bouncing under high RPM's.
Stretched timing chain is a good possibility too since it gets worst under heavy pressure.
I'd check things out with a timing light first. Then do a compression test.
If you suspect slop in the timing chain test by putting a socket on the bottom pully and see if your getting any movement on the crankshaft that isn't immediatelymoving the camshaft.
Old October 13th, 2008, 12:26 PM
budsjlm's Avatar
k question with the botom line there what is the best way to tell if i have moovement on the crank and not imediatly at the cam with out tearing down the front of the motor
Old October 13th, 2008, 4:32 PM
Scootertrash's Avatar
Had this issue with an 81 Chev P/U w/305. Pull the passenger side valve cover and look at the valves on the front 2 cylinders and make sure they are opening and closing. The problem with mine was worn cam lobe, which was common on the 305. It was a wornexhaust lobe so the exhaust valve didn't open and there was still pressure left when the intake opened causing the pop. Pop wasn't noticeable until opening the throttle a bit. I think you'll find your problem there. If not the pass side then try the drivers side.
Bud-Where in MN are you?
Old October 14th, 2008, 10:46 AM
budsjlm's Avatar
igh south burbs right next to wsp
Old January 2nd, 2010, 5:44 PM
budsjlm's Avatar
Conclusion tore up cam lobe... motor and trany are out and waiting on money
Old January 31st, 2010, 12:32 AM
timmysouthpark's Avatar
1. Timing
2. Timing chain /gear worn out
Old February 10th, 2011, 11:46 PM
Maxy's Avatar
Just got a hold of an 87 cutlass with a 350 in it. Set top dead center timing and tried to start it. Keeps popping through the carb no matter how u move the timing.
_____________________________________________
Rvs For Sale Classic Cars For Sale
Quick Reply: HELP! 305 poping throught carb HELP!
