ineed help ! P0455
ineed help ! P0455
Helo there every body !
i have a Chevy trailblazer 2006 LT, my problem is the check engine caused by P0455 , gas cap not tight triggers check engine ! IF any one has successfully repaired the issue , please show the way ,, Thank you all ,, thanks also to the administrators,,,hope to hear great tips soon ,, take care
the evap system must seal itself to perform leak check diagnosis. if the evap vent solenoid does not close, a large leak dtc will set. check for power to the evap vent solenoid. it should have power with the key on. provide a grd for the vent solenoid. it should click when it opens and closes. if it doesn't, the solenoid is bad.
Thanx a milliom tech 2! this is very helpful hint ,,, any one else owns a trailblazer 2006 had this problem gas cap not tight P0455 which triggers check engine and has successfully repaired the issue , it seems like this issue is common with this model... loots of cheers again to all of you
Upppppp ,,, please help
EddieClassic07
Silverado & Fullsize Pick-ups
December 11th, 2011 1:53 PM
