Notices
I have a 94 GMC with transmission problems. Help!
Old December 31st, 2008, 4:02 PM
rdmm19's Avatar
Default I have a 94 GMC with transmission problems. Help!
It's beginning to slip out of second gear (when gas is pressed down hard) and overdrive! Has anyone else had similar problems? Also - if the transmission needs to be replaced, would it be smarter to use an aftermarket or heavier-duty trans instead of the one that is made for the truck? Please help!
Old January 2nd, 2009, 9:03 AM
Default RE: I have a 94 GMC with transmission problems. Help!
I'm guessing the tranny has been serviced regularly and the fliud has been checked and the filter repalced, being a 94 I'd guess you have at least 170k miles on it, it could just need a band adjustment but more then likely the clutches are getting worn out and it may need to be rebuilt. A transmission shop could give you a quick assesment.
having it rebuilt is usally cheaper then replacment but sometimes if you can get a good deal or a factory refurb a shop with can change them out for you for a few hundred bucks.
wannabegearhead
July 14th, 2014 9:50 PM
Deamonmk2
Silverado & Fullsize Pick-ups
September 5th, 2013 8:08 PM
xzerobeatx
April 29th, 2010 9:44 PM
zetakappa700
January 28th, 2008 7:49 PM
Quick Reply: I have a 94 GMC with transmission problems. Help!
