Intake Manifold Cover - Taking it off - Chevrolet Forum - Chevy Enthusiasts Forums
fschlenter911's Avatar
January 9th, 2011, 2:17 PM   #1
Hello,
I have a 2007, Chevy Avalanche, V8, and would like to clean the Throttle Body Intake. But, I don't see how to get the Intake Manifold Cover off. I am using a Haynes Repair manual and I don't see a reference to it. When I visually look, I don't see any obvious screws.
I would appreciate some advise.
Thanks,
Austin, Texas
January 9th, 2011, 5:26 PM   #2
I'm guessing you are wanting to clean it for possible carbon build up?
You would probably be just fine cleaning the throttle body only.
January 9th, 2011, 5:30 PM   #3
Yes...but?
Yes, that's all that I want to do. How do I get the Intake Manifold Cover off?
It isn't obvious to me.
Thanks
quote=in2pro;168831]I'm guessing you are wanting to clean it for possible carbon build up?
You would probably be just fine cleaning the throttle body only.[/quote]
Austin, Texas
January 9th, 2011, 5:41 PM   #4
I'll take a look at my factory service manual when I get home this evening and see what I can post if someone is not able to answer it before them...
January 9th, 2011, 9:42 PM   #5
Thank You;
I really appreciate that.
Posted By: in2pro I'll take a look at my factory service manual when I get home this evening and see what I can post if someone is not able to answer it before them...
MDTAHOE's Avatar
Professional Mechanic
Bowie, MD
January 9th, 2011, 10:38 PM   #6
The plastic cover that says Vortec on it?
Austin, Texas
January 11th, 2011, 8:35 PM   #7
2007 Chevrolet Avalanche - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 1670161
Intake Manifold Removal (RPO LC9/LY5/LMG/L76)
Important:
The intake manifold, throttle body, fuel injection rail, and fuel injectors may be removed as an assembly. If not servicing the individual components, remove the manifold as a complete assembly.
DO NOT use the intake manifold-to-cylinder head gaskets again.
Remove the positive crankcase ventilation (PCV) hose - dirty air (716).
Remove the manifold absolute pressure (MAP) sensor (714) and retainer (736), as required.
Remove the O-ring (715) from the sensor, as required.
Remove the intake manifold bolts (512).
Remove the intake manifold (500) with gaskets.
Remove the intake manifold gaskets (514).
Discard the intake manifold gaskets.
Tags
Sponsors
