Job diagram - Changing oil pump
Oil Pan Replacement
Removal Procedure
Oil Pump, Screen, and Crankshaft Oil Deflector Replacement
Removal Procedure
Removal Procedure
- Remove the oil level indicator tube.
- Raise the vehicle.
- Remove the engine oil and the engine oil filter.
- Remove the oil filter adapter.
- Remove the starter.
- Remove the engine mount through bolts.
- Remove the oil pan.
- Note the location of any studs to assist reassembly.
- Remove the engine oil pan and the oil pan gasket.
- Clean all the sealing surfaces.
Removal Procedure
- Remove the engine oil pan.
- Remove the oil pump.
- A loose oil pump screen or pipe assembly can result in an air leak and loss of oil pressure.
- If the tube is loose in the oil pump body replace the oil pump screen.
Important: Install a NEW oil pump driveshaft retainer.- Install the oil pump and the crankshaft oil deflector.
- Install the engine oil pan.
aboyaser
November 20th, 2012 9:04 AM
greatwhite99
October 21st, 2011 8:44 AM
