Notices
Just lowered my 07 tahoe, and ABS and Traction control light is on! Help?
Old February 20th, 2009, 7:19 PM
michael n's Avatar
Default Just lowered my 07 tahoe, and ABS and Traction control light is on! Help?
Hi guys!
I just had a guy install a ground force lowering kit for me, part # G379856, or 9856. (Depending on where you search.)
The package came with:
2 front spindles.
2 rear shocks
2 rear coils
and rubber bump stops.
He installed it and all of a sudden the lights came on. What should I do? Take it to a dealer? Or is there some way to reset this?
any help is appreciated.
thanks!
Old February 22nd, 2009, 1:42 PM
jwruss's Avatar
Have you checked for loose, unplugged or broken wires in the areas he worked?
Old February 23rd, 2009, 2:24 AM
michael n's Avatar
hey, thanks for the reply. yes i did. then i even-- reluctantly took it to the dealer. they didnt have time to officially look at it, but the service advisor crawled under and checked it out too and couldnt find anything.
i guess im just going to take it in tomorrow and let them see what they can find. i was hesitant on doing that since dealers are always quick to say "well its gonna cost $XXX to fix the damage caused by the mods you did to your vehicle." will update once i get an answer.
Old February 26th, 2009, 12:25 AM
michael n's Avatar
Hey,
just wanted to update and thank jwruss
Just got it back from the dealer and they found a torn wire going to the abs sensor. apparently if there is ANY fault in the abs, or traction control- both fault light come on because they work together..
anyway its good to go.
Old February 26th, 2009, 9:39 AM
EvansBlue's Avatar
Yeah I was about to suggest the wheel speed sensor wire.... Glad you got it fixed.
Lowering kits are tricky. Mine left me with a brake problem that began several days after lowering. It had be baffled, but thanks to shawnvw on the forum, I replaced the flexible brake hose and its fine.
Thanks for thanking who gave you advice. Its always nice to let them know that they were spot-on.
Old February 23rd, 2013, 4:41 PM
Denise Miller's Avatar
How do I reset my abs light on my 2007 tahoe
RJK
January 29th, 2024 5:56 PM
rlnewell
Equinox
245
August 2nd, 2017 2:15 PM
idk2050
March 24th, 2015 9:32 AM
xastrosrulex
Silverado & Fullsize Pick-ups
June 9th, 2011 12:41 PM
Quick Reply: Just lowered my 07 tahoe, and ABS and Traction control light is on! Help?
