Notices
Lucas Oil Products?!
Old November 3rd, 2007, 7:00 PM
mudderfan's Avatar
Default Lucas Oil Products?!
Has anyone used the Lucas Oil Products? They make the oil stabalizers and tranmission fluids stuff. Any info on those?
Old November 3rd, 2007, 7:18 PM
DAVID L. PAUL's Avatar
Default RE: Lucas Oil Products?!
I USE THE OIL STABABLIZER EVERY OIL CHANGE I USE MOBILE 1 AND 1 CAN OFF STABABLIZER AND I'VE GOT 280+THOUSAND ON A 94 SUBURBAN WITH 350 THROTTLEBODY AND DON'T USE ANY OIL BETWEEN CHANGES
Old November 3rd, 2007, 8:08 PM
mudderfan's Avatar
awesome to know. i have a 93 1500. i use mobil 1, but havent used the oil stabalizer yet. wasnt sure if it was a difference maker. but it sounds like it is. thanks
Old November 4th, 2007, 4:23 PM
marky660's Avatar
i have a 03 1500hd crew cabwith a 6.0 ,85.000 miles. past two oil changes i used lucas and castorl gtx and i get up to 19mpg not all the time mostly i get around 17
Old November 4th, 2007, 10:02 PM
Scoper50's Avatar
Neither motor oil or oil additives will give you increase gas milage. No matter what oil you choose, it will not increase performance, it will not give you increased gas milage, and it will not increase horsepower. Oil is a lubricant, plain and simple. All it does is lubricate.
Old November 5th, 2007, 7:07 AM
syntec oil will improve gas milage maybe not much but it will improve it anytime you cut down on friction you will improve fuel milage and gain a little more power
Old November 6th, 2007, 12:37 AM
Scoper50's Avatar
Synthetic oil doesn't decrease friction except at the initial cold start. Furthermore, even if synthetic oil did decrease friction at operating temperature, any performance gains or gains in fuel milage would be so minimal and insignificant, they would be practically unmeasurable, and definetely unnoticeable.
jimsimm
April 17th, 2020 11:56 PM
ukrkoz
Silverado & Fullsize Pick-ups
March 4th, 2012 3:16 PM
sailor
April 7th, 2009 6:38 PM
smmenterprises
October 5th, 2006 12:08 AM
Quick Reply: Lucas Oil Products?!
