Notices
MAP sensor??
Old November 25th, 2006, 5:26 PM
maddmatt16052's Avatar
Default MAP sensor??
Hi,
I have 1987 caprice 4.3 V6 fuel injected. I am replaceing the MAP sensor (since my code scanner read that it was bad. I bought it but I can't find it in my car ,The haynes manuel says it is attached to the air cleaner but it is not there!?? can any one help me out with this one? I am going to try and attach a pic of the new sensor.
Thanks,
Matt
[IMG]local://upfiles/4986/33455F910D024CF6910A8CE970236FEA.jpg[/IMG]
[IMG]local://upfiles/4986/9A6C3D1DA9064EF7A3DC4B555993BFDF.jpg[/IMG]
Old November 25th, 2006, 7:49 PM
buster's Avatar
Default RE: MAP sensor??
That does'nt look like a map sensor.
Old November 25th, 2006, 9:17 PM
70mopar's Avatar
looks more like a knock sensor.
Old November 25th, 2006, 9:22 PM
That is why I took the pic. I didn't think so (but I have no clue) that's what the auto parts store gave me. I'm taking it back tomorrow and I'll let u know
Thanks,
Matt
Old November 25th, 2006, 10:14 PM
buster's Avatar
70mopar may know better than me, but the MAP sensor should be just to the right (as you're seated in the car) of the throttle body, mounted on a bracket with an elect plug & a vacuum line on the other end. sort of rectangular shaped.
Old December 1st, 2006, 6:54 PM
I found out where the map sensor is, it is on the firewall wityh a hose coming from the throttle body, my problem was a dry rotted hose! I replaced it and now the car is running perfect again
thanks for all the help,
Matt
kyina
Silverado & Fullsize Pick-ups
13
July 12th, 2011 9:28 AM
USR_BS
May 27th, 2010 10:46 AM
frgazda
December 3rd, 2008 11:56 AM
gungfu01
February 9th, 2007 11:30 PM
Quick Reply: MAP sensor??
