Motor just stops
car stops
Sounds like the fuel pump is doing its initial run when you turn the key on but not running when the motor starts. You need a diagnostic chart to see where it feeds from. I am away from my books so cant help on that. Some feed thru the oil press switch so if the oil press drops it kills the pump. Some have a collision switch that shuts the pummp off in case of a crash. Hope this gives you some ideas.
