Notices
NEED HELP back pressure in my valve covers tons of white smoke in exhaust
Old October 15th, 2009, 3:52 PM
fishn4112's Avatar
Exclamation NEED HELP back pressure in my valve covers tons of white smoke in exhaust
i have back pressure building up in my valve covers that blows off my filler cap and pcv valve which is new and working there is also alot of smoke out the tailpipe and black carbon or oil dripping out the tailpipe 92 s10 blazer 4.3
Old October 15th, 2009, 4:38 PM
old dog's Avatar
Default pressure
not sure but sound's like you have a busted piston or rings pressurizing the crank case or the pcv system is not working .how much water in the exhaust and when ?pressure check the cooling system ,to rule out a blown head gasket .
Old October 15th, 2009, 5:58 PM
Professional Mechanic
MDTAHOE's Avatar
Pull the hose off the other valve cover (opposite of PCV valve) see if it will suck a piece of paper against the valve cover. If it does not the pcv passages are blocked in the valve cover.
Philly
January 5th, 2014 7:25 AM
454BBC
Silverado & Fullsize Pick-ups
April 30th, 2013 5:48 PM
Viperdude5064410
May 1st, 2009 11:14 AM
rabbit0102030
11
June 6th, 2008 7:11 AM
Quick Reply: NEED HELP back pressure in my valve covers tons of white smoke in exhaust
