Notices
No oil pressure reading, 2004, Silverado
Old October 12th, 2009, 1:20 PM
JimOmaha's Avatar
Default No oil pressure reading, 2004, Silverado
The Chilton manual is not leading me to the oil pressure sending unit. It shows it as metal and tubular that mounts behind the rear of the intake manifold. I removed the ductwork to the throttle body but don't see the sending unit.
It is a 4.3L automatic. Can anyone help me with this?
Sincerely, Jim
Old October 12th, 2009, 3:58 PM
Ride of the Month
May 2009
mudmaniac's Avatar
It should either be at the driver's side rear of the block or on top of the oil line connections on the side of the block.
Old October 12th, 2009, 5:34 PM
therewolf's Avatar
Cool
Hi Jim Omaha,
Welcome to the Chevy forums.
I don't know if this pertains to your particular vehicle or not, but generally speaking, the oil sender unit is located somewhere close to the oil filter. If all else fails, try searching around your oil filter, and see if you can spot the wire(s) or plug leading to the oil sender unit.
Old October 12th, 2009, 8:08 PM
Professional Mechanic
MDTAHOE's Avatar
It should be on the back of the engine block just past the intake. Reach further back.
Old October 13th, 2009, 1:07 AM
JimOmaha's Avatar
Default Search for oil pressure sending unit
Hey thanks!
I really appreciate the helpful information. I will search again for it. Has anyone found the connection on the sending unit to be faulty? Or even the sending unit itself? I guess my reasoning is; I work with two other guys who have 2004 Silverados and they have experienced trouble with the stepper motors in the cluster assembly. Does this sound familier to anyone? Is this more likely the culprit?
I appreciate all information!
Sincerely, Jim
Old October 29th, 2009, 1:38 PM
JimOmaha's Avatar
It ended up being the stepper motor in the cluster ***'y (dash board). I repaced all six and the bulbs since I was there.
Steelman512
June 8th, 2023 2:51 PM
drgnflys
November 26th, 2014 12:52 PM
tom5170
Silverado & Fullsize Pick-ups
February 25th, 2014 12:06 AM
not_a_car_dude
September 15th, 2013 7:41 PM
Cybrjaz
Avalanche
February 25th, 2013 9:30 AM
Quick Reply: No oil pressure reading, 2004, Silverado
