Nylon timing gears
Nylon timing gears
I was wondering if there was a way of figuring out for sure what type of timing gears came in my car. GM loved to use those wonderfully awful nylon coated timing gears. I think I will have to take off the cover, but as it is the 3.8 from the late seventies, it has that complex looking timing cover, i am a bit worried about it. It almost looks like the water pump is integrated into the thing.
As it is an interference engine, I need to figure this out before the thing goes.
RE: Nylon timing gears
I'd assume they were nylon coated and just go ahead and replace them. Usually they don't fail catastrophically but allow the timing chain to skip a tooth or two which changes the timing which will make the engine hard to start, if at all.
ChevyRocker
September 20th, 2011 7:00 AM
gulfcoastjoe
May 10th, 2008 3:23 PM
gulfcoastjoe
April 28th, 2008 2:37 PM
