Oil leak.
Oil leak.
So I have an oil leak that I can not find!!! It leaks a puddle the size of a dollar bill overnight. The weird thing is I just replaced my Rear main seal and Oil pan gasket. I also noticed it drips on my Slave cylinder which would mean it is also on my passenger side of the vehicle. Also there are some drips on my exhaust manifold. Where could this be coming from. It wouldnt be my Head gasket or there would be water in my oil right? And Valve cover would not leak that bad would it? Thanks' guys!
ROTM Coordinator
ROTM Coordinator
Actually I took a closer look and what I thought was oil on the manifold was black plastic melted. And I looked and it looks like my oil Filter adapter is leaking. I am looking but no one can find just the gasket. I think it has a paper gasket and then a rubber O-ring can anyone confirm this?
Professional Mechanic
Actually took another look at it and it is all over everything, Oil filter, bottom of oil pand and bolts, Slave cylinder. Where else could this be coming from?
Clean everything off with brake clean or carb cleaner start the truck up and watch for the leak. If everything is that wet then you should be able to find the leak after it runs for a few minutes. Is the brake fluid level low in the clutch reservoir
Hey, Suzuki Guy, Captain Obvious here.
I've seen about a billion(OK, 63,952) old PCV valves go bad, then the pressure builds up under the valve covers, and viola! Leaky valve covers! You are probably well aware of this, but is it possible that you have a defective NEW PCV valve which is causing you this grief?
As far as your valve cover question, you can have them leak that bad. I just did valve cover gaskets on a friends 95 Regal. The back one was leaking so bad that the car would smoke driving down the road from oil dripping down onto the exhaust.
I would either go for your oil filter mount or the valve covers. Like its already been said, the best way to check for leaks is to clean everything off real good and then watch to see if you can see where its coming from.....or just let it run for 10 minutes and come back out and follow the oil line from where it leaked. I wouldn't do brake cleaner though cause it can get expensive.....a can of brake cleaner doesn't go very far, especially if your motor is excessively dirty. Just get yourself a pressure nozle for your garden hose and some de-greaser to clean the entire motor while you're at it.
Are you sure that you installed the rear main correctly?
