P1345 code from 2001 Safari???
My 2001 GMC Safari has a service engine soon code of P1345.
The van has 75k and never had a problem until now. I did change
the cap and rotor and the light came back on. Please help
redvette
redvette
RE: P1345 code from 2001 Safari???
ORIGINAL: redvette
redvette
redvette
Changing the cap and rotor ( although wouldn't hurt ) won't correct this fault.
There is a problem with the cam position sensor circuit or the crank position circuit.
Thanks for the help. The engine was also making a slight tapping noise from the front.
I replaced the Crankshaft Position Sensor and the noise stopped and the check engine light is now off. The part was $60 at AutoZone and they loan you the OBCII Scanner at the store.
Redvette
Redvette
try disconnecting the battery for a bit to see if that will reset the computer
or u might have to have the code cleared with a scantool of some sort
assuming that the problem is fixed
good luck
good luck
seamorewatervip
January 14th, 2013 6:13 PM
