Speedometer/Odometer Help
First of all, I'm not sure if there's already a thread here on this topic, so if there is sorry for reposting.
My van is a 1982 Chevy G20, and my speedometer quit working along with my odometer. I noticed that the odometer kept rolling back ever so slightly, so I removed the dash to get a look at the cable... Sure enough, the cable is rolling backwards, but not forward. I traced the line and everything looks hooked up, but I have yet to put my hand on it and see if it was tight or not, but I was wondering offhand if anyone might know the source of a problem like this. I'm pretty sure if the cable were broken, it wouldn't spin at all. I'm hoping it has nothing to do with the transmission. It did stop working once for about a day, but then returned to normal. The speedo also has had a jump in it while traveling if that helps.
Any knowledge would be greatly appreciated. Thanks!
Backwards...strange !
You need to get under your ride and check the Gear that's inserted into the transmission. Got to be something there...stripped...something.
An easy fix if that's it.
While you got the Gear out of the Tranny, be sure to spin it to see if there's a possible snag in the Cable or Speedometer Head.
Josh_Br
Silverado & Fullsize Pick-ups
March 10th, 2015 10:56 PM
qureshza
December 23rd, 2012 11:03 PM
