Notices
trailer light wiring
Old March 19th, 2008, 1:34 PM
jsp2002's Avatar
Default trailer light wiring
I just bought a trailer and trying to get the trailer lights to work right. Towing with an 02 suburban. When I have my headlights on the lights on my trailer seem fine. However, with the headlights on, when I press the brake my brake lights on the trailer turn completely off. All of the running lights stay on. With the headlights off when I press the brake the brake lights on the trailer work. Any suggestions???? I tried changing the wires around and it still does the same thing.
Thanks,
Jon
Old March 19th, 2008, 3:50 PM
TransAm Man's Avatar
Default RE: trailer light wiring
Good luck with rewiring it
Old March 20th, 2008, 2:55 PM
Banned
shawnvw's Avatar
Have you installed a module that will go from a 5 wire system that your suburban has, to a 4 wire system that your trailor has(if it is a 4 wire system).
something like this http://www.etrailer.com/pc-VWH~118175.htm
When applying the brakes with the lights off, are they bright like brake lights should be?...or are they the same brightness as the parking lights are? if so, check to make sure the wires are run properly to each light.
Old March 23rd, 2008, 12:08 PM
xtremejimmy's Avatar
any luck with it yet? I am having the same exact problem with my 97 silverado. I just put new wiring on my trailer since the old ones were all corroded. I already replaced the plug on the truck with no luck. Re-did the ground wire as well with no luck. Still cant figure out what it is.
Old March 24th, 2008, 11:43 PM
old dog's Avatar
question does this have a factory plug on it ? if you put a different plug sounds like there are some wires hanging out of the plug where they are installed from the running light function the touching the brake lite pin,if factory 7 wire check for corrision in the plug under the lift up door,disconnect the wire connector from the plug ,check ther also sounds like voltage crossing over .
intheknow
July 24th, 2014 10:38 AM
billhemingway
May 4th, 2010 3:53 PM
mgoddard
Express & G-Series Vans
August 2nd, 2007 4:51 AM
marnold1025
Uplander
April 30th, 2007 11:29 AM
connman119
August 23rd, 2006 9:13 PM
Quick Reply: trailer light wiring
