Transmission Problems??
Hello everyone,
I'm coming with the following OBDII Codes, and I was wondering if there is anything that I can do to further diagnose the issues myself?
p0742 Torque Converter Clutch Circuit Stuck On
p0757 Shift Sloenoid "B" Stuck On
Thanks in advance,
-Kirk "The non-mechanicaly inclined Venture owner
Thanks in advance,
RE: Transmission Problems??
You should check the wiring to them. just because the computer says there's a problem with them doesn't mean the component itself is bad. You should also make sure that everything else in the same circuit as those components is functioning properly.
-Bizzy
-Bizzy
Coravir
Silverado & Fullsize Pick-ups
October 26th, 2019 3:28 PM
DSGB
May 29th, 2013 8:54 AM
