2006 HHR LS PWR Steering
My 2006 HHR tends to drop it's PWR Steering within a block of starting it. I cannot find a reservoir for fluid. Is this an electric system, and what is the cure?
The PWR Steering comes back when I start the car but fails soon after starting the car, speed and distance are not an issue that I can describe; however, at times I can drive up to 1/2 mile under 20 MPH before failure occurs.
Is this a speed/distance issue? I can drive in a circle for 2-3 minutes before it fails!
Befuddled....
Befuddled....
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Kazcheff,
I’m sorry you are experiencing this issue with your HHR. Would you please PM me the last 8-digits of your VIN, so I may look into this further.
Louis
GM Customer Service
Louis
GM Customer Service
Befuddled....
Befuddled....
wasn't there a recall for the ps motors for the cobalts of that year?
The HHR is basically a cobalt. customer service will check to see if that recall applies if you pm them your vin
Bogeymanmcs
Equinox
September 1st, 2010 9:27 AM
