HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
HHR oil filter location?
Old January 28th, 2006, 1:39 PM
dhuberasu's Avatar
Default HHR oil filter location?
Looking for oil filter on HHR with ecotec 2.4L....can anyone help me!??? Location on car....
thank you
david
Old March 21st, 2006, 9:08 PM
Hhute's Avatar
Default RE: HHR oil filter location?
HHR does not have the traditional Oil filter, the oil filter is within a housing in front of engine slightly to the right on the driver side. The screw on/off Hex(32mm) black plastic cap is visible as you peep down facing the engine. The filter fits down into the housing.
Old June 19th, 2006, 9:20 PM
Vettebuilder's Avatar
It is off center to the right side. It is in a canister, which is black and has a large hex head on top for filter removal.
I hope that this helps.
Joe
oop's like they said in post #2
Old July 23rd, 2006, 7:34 PM
NCHEVYHEVN's Avatar
You will also have to remove the engine cover inorder to see it. Pretty self explainatory but remove the oil cap and pull on the cover and it should pop off. Some are on there pretty tight though.
Also if you don't have a 32mm a 1 1/4' will also work. You'll also need a good sized extension to reach.
Also I have heard that if you don't change the filter first then you actually leave a 1/2 a quart of dirty oil in the motor. But that is just what I have heard not sure if it's actually true.
Old May 5th, 2008, 12:13 PM
cccoveguy@yahoo.com's Avatar
I know this is an old post, but... wanted to be sure to bring to everyone's attention that the advice that a 1 1/4" socket will work instead of 32mm was right on! At the closest parts store they were out of the 32mm size but had 1 1/4" so I took a chance and it worked just great.
PeterPiper
Sonic (Aveo)
17
February 6th, 2010 1:10 PM
trush
January 1st, 2008 9:27 PM
downsouthplaya
July 9th, 2007 11:54 AM
tacogs
November 12th, 2006 8:25 AM
dannyburt
HHR
August 25th, 2006 10:54 PM
Quick Reply: HHR oil filter location?
