HHR This retro crossover vehicle combines the usefulness of a minivan with the size of a mid sized car.
Platform: Delta
Also Check out ChevyHHR.net
transmission shift cable and shift leval at transaxle
Old August 28th, 2016, 2:54 PM
GRAHAMR's Avatar
Default transmission shift cable and shift leval at transaxle
what holds the shift cable to the shift lever cause whatever fastened them is worn out,suggestions how to secure them together. This is on a 2007 hhr
Old August 29th, 2016, 1:47 AM
I am not sure what your linkage on the HHR looks like, but when this happened on my Trailblazer, I drilled out the old connector and used a small shoulder bolt and nut to connect the cable to the arm on the transmission. It worked well.
