body slide after parking
First of all, hi!
Looks like I've finally found the right place to hangout.
Anyways, it's about my 2007 Impala LT.
It didn't happend until couple of months ago.
Whenever I parked my car, my Impala tends to slide a bit. I mean a lot compared to the other cars.
So I took to the services but they told me that it's normal. One guy even told me that it's a 'feature', called something-brake-system. Two different service shop, same opinion; no problems found.
Everyone in my family noticed the sliding.Some says not much, but Ifeel it almost every time when I park.Over the years, our familyowned 8 different cars, 4 of them Chevy, but never had this kind of problem/issue/feature(?).
So I did a little testing. I parked my Impala on a flat surface,then pushed the car car a little.Even with not alot of force, the bodyslided quite a few inches.I tested with other cars that was parked on our house but no other cars moved as much as my Impala. I told this to the service but they told me that every car is different and there's nothing we can do about it. They adviced to use parking brake, but come on..
Am I being too sensitive? Is it really nothing to worry about?
Thanks for any replies.
RE: body slide after parking
MY 08 ALSO WILL MOVE A LITTLE IN PARK, ON A FLAT SURFACE IF YOU LEAN ON IT, AS THEY SAY, IF IT BOTHERS YOU USE THE PARKING BRAKE ALSO.
I THINK PART OF THE MOTION IS FROM THE MOTOR MOUNTS FLEXING.
So I guess it's really nothing to worry about. Never had a car that slides this much. Now I know that at least there isn't a problem in my car... I think..
Can you tell me more about the motor mounts flexing? I've googled but got no clear answers. I'm a bit car noob but I'm here to learn.
( Andtyping inCAP usually means YELLING on the net, just to let you know. [8D])
If you open the hood & rock the car back & forth, you will notice the engine moves some, that is the motor mount flex I referred to.
The mounts are made of rubber to eliminate noise and vibration being transfered to the body.
Kinnup7
September 26th, 2022 12:05 AM
Seljeskogs
Silverado & Fullsize Pick-ups
May 23rd, 2009 12:43 AM
