2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2003 impala won't pass emissions
Old August 18th, 2014, 11:04 AM
impala2003's Avatar
Default 2003 impala won't pass emissions
2003 chevy impala 3.4
using innova 3100 diagnostic tool scanner reads no fault codes
No engine light on in car. Let car sit 8 hours on three separate occasions.Ran drive cycles. system status light stays yellow. will not go into readiness which is green. All seven items pass emissions except ev - meaning evap. Has anyone encountered this problem before and if so, how did you repair?
Could sensors be bad and won't send fault codes.
Old August 18th, 2014, 8:51 PM
one of the conditions for the evap monitor to run is: the fuel level must be less than 3/4 full and more than 1/4.
Old August 19th, 2014, 8:10 AM
impala2003's Avatar
It has 1/2 tank of gas
Old August 19th, 2014, 10:20 AM
impala2003's Avatar
1/2 tank of gas. New battery. Ran Drive Cycles 4 times. 250 total miles driven over a week.
Old August 19th, 2014, 10:38 AM
Frank3's Avatar
I had a similar problem with my Saturn years ago. The thermostat was bad and never allowed the engine to come up to full temp, so the evap test was inhibited until temp "X" was reached.
Old August 21st, 2014, 2:37 PM
impala2003's Avatar
Thanks Frank3. Got halfway through drive cycle step 2 and ev light came on within four miles. Unhooked the fan motor and didn't turn AC on and it passed emissions. Thanks for your feedback, that suggestion did the trick.
Tony
Old August 21st, 2014, 3:08 PM
Frank3's Avatar
Tony, I'm glad things worked out for you!
nick faris
May 24th, 2015 4:01 PM
mariposawrick
December 31st, 2014 12:17 AM
mamameg24
January 8th, 2014 1:34 PM
motomonte
August 27th, 2008 8:18 PM
Euro92
April 5th, 2006 4:17 PM
Quick Reply: 2003 impala won't pass emissions
