2008 Impala Engine code help
Hi, I have a 2008 Impala (police pkg) that has been giving me problems the past 2 months. Every once in a while (once a week) I will try to start it and it will bog, hesitate, run rough. Then when I drive it, it will shift hard into gear and has not much power. About 10 mins later it will be fine. I have brought it to my shop and even left it over night for them to test. The engine light has come on a couple of times. They have replaced the wires, plugs ingintion coil and air filter. The light went on today and I was able to capture the codes. Does anyone have any idea what is going on? Here is the codes from today
2008 Chevrolet Impala 3 = 3.9
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refirg Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refirg Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0069 ENG
Manifold Absolute Pressure – Barometric
Pressure Correlation
HISTORY MIL
P0106 ENG
Pressure Sensor Range/Performance
CURRENT HISTORY MIL
P2228 ENG
Barometric Pressure Sensor Circuit Low
Voltage
HISTORY MIL
P0069 MOD $00
CONFIRMED
P0106 MOD $00
CONFIRMED
____________
P2228 MOD $00
Voltage
CONFIRMED
P0069 MOD $00
PENDING
P0106 MOD $00
PENDING
<!-- / message -->
I/M Monitors
Since DTCs Cleared
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refirg Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
This Drive Cycle
Misfire Monitor ok
Fuel System Mon ok
Comp Component ok
Catalyst Mon inc
Htd Catalyst n/a
Evap System Mon inc
Sec Air System n/a
A/C Refirg Mon n/a
Oxygen Sens Mon inc
Oxygen Sens Htr ok
EGR/VVT Sys Mon n/a
DTCs (Codes)
P0069 ENG
HISTORY MIL
P0106 ENG
CURRENT HISTORY MIL
P2228 ENG
Voltage
HISTORY MIL
P0069 MOD $00
CONFIRMED
P0106 MOD $00
CONFIRMED
____________
P2228 MOD $00
Voltage
CONFIRMED
P0069 MOD $00
PENDING
P0106 MOD $00
PENDING
<!-- / message -->
Total Shot in the dark on this, as I'm pretty car retarded, but I'd consider checking the MAP Sensor Hose and seeing if it's gunked up or clogged somehow.
Otherwise, I'd start pricing a MAP sensor... *shrug*
