2009 Impala Steering Column Trim and Levers Removal
I am attempting to remove the main dash plastic panel from my Impala. The (seemingly) last steps I need to take are:
According to a service diagram I should disable the airbag and simply pull out the tilt release lever, but so far I've had no luck. I can try again if no one points out another way to do it.
I need a Torx driver to remove at least the steering column trim. I don't know which size and if someone could tell me that'd be great, otherwise I'll buy a whole set.
According to a service diagram I need to undo fasteners for the multifunction lever. I don't know what kind of fasteners these are as I haven't seen them yet. If anyone else has ideas or knows, that would also be great.
- Remove the steering wheel tilt release lever
- Remove the steering column trim
- Remove the multifunction lever (turn signals, wipers, etc)
EvansBlue
S10 & Blazer DIY and Useful Threads
August 31st, 2015 9:43 PM
glenn irwin
Silverado & Fullsize Pick-ups
October 18th, 2010 12:12 PM
taylorisafop
December 19th, 2008 4:57 PM
