Battery Drain Issues
Hello all!
I have a 2006 Impala. I am having issues with something draining the battery to the point it will not start. Whatever is doing it doesn't do it all the time. Its only occasional and random so its hard for the garage's/dealers to find it. When I took it in they couldn't get it to do it. But once whatever it is triggers or doesn't turn off when the car is shut off it takes about 8-9 hours for the car to sit to drain the battery.
A few days ago I got done at work and came out and the car started "hard" as the battery was almost dead. I just happen to catch it in time. As it struggle to turn over and start the dash flashed a message that said "Automatic Control Light On". I hadn't seen this before. I tried to google that message and I get a lot of traction control links, but I'm not sure if that is what the car message is referring too. I cant find anything that refers to the actual exact wording of the message the car flashed however.
I have already replaced the battery and starter trying to solve this battery drain issue. So those are new.
Anyone have any ideas? Any help would be greatly appreciated.
Thank you!
Thank you!
Hello all!
Thank you!
Thank you!
If you have an under hood trouble light, and you are having this issue, unplug it. My 2000 suburban had this issue.
