2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
2014 ImpalaLTZ incorrect outside temp readings
Old April 18th, 2015, 7:29 AM
allison1212's Avatar
Default 2014 ImpalaLTZ incorrect outside temp readings
I have a 2014 Impala LTZ that gives incorrect outside temp readings. The ambient temp sensor was changed, but did not correct the issue. Any help would be appreciated. Thanks
Old April 18th, 2015, 8:05 AM
Default probably nothing wrong
if its like the trucks; the reading is not always live. the sensor is located near the radiator...a heat source. it uses an algorithm to compensate for the influence of the rad. it will update when the proper conditions are met.
Old April 18th, 2015, 8:44 AM
The car is a wreck. Had some damage on the rear trunk and a quarter panel. From the back doors forward the car was immaculate. 6K miles I had hoped it would go away with the new sensor. No such luck
Old April 18th, 2015, 3:33 PM
sledge.impy's Avatar
You are talking about the one on the mylink console, upper left corner?
How incorrect is it? Like 5 degrees? 10? 50? 100? Reads NULL? Up or down? fluctuates wildly?
Old April 19th, 2015, 8:34 PM
Default Outside temp issue
It is the one you are speaking of. Sometimes it reads 140 sometimes it shows no temp at all. It appears to alway read extremely high or not at all.
TMDalSanto
HHR
February 24th, 2012 7:37 PM
montana suburban
May 11th, 2010 5:19 PM
JCRAMOS
January 9th, 2010 10:41 AM
blkcloud
September 21st, 2009 9:24 PM
mrsmoos
June 1st, 2008 11:14 PM
Quick Reply: 2014 ImpalaLTZ incorrect outside temp readings
