3.4 Supercharger
Impala Super Moderator
RE: 3.4 Supercharger
turbo is better than the supercharger...
Turbo :
-We HIGHLY recommend you buying a intercooler too to go with a turbo or supercharger
Cartunning Performance Turbo - Will work for 3.4 with MINOR modification
buy now
Stattama Turbo kit - Same, should work with MINOR modification
buy now
Misc. Kit For Grand Am
buy now
Supercharger :
RSM Racing is the only company that makes a SC for the 3.4L. NAIOA Recommends a Turbo over Supercharger!
buy now -will more then likely require some custom work, but none the less, it should work
Turbo :
buy now
buy now
buy now
Supercharger :
only a guysellin a turbo would tell you its better....LOL..
should not be hard there are kits out there for them, and although Turbos have come a long way, Superchargers are easier and simplier..and no spool up times, Turbos will make more power tho.
another optioin check slavage yards for a Impala SS or Monte SS and snag the 3.8 S/C engine from it, and bolt it in.
no you could swap the whole engine.......OR see how diffeent the 3.4 is from the 3.8, you may be able to bolt on the top end and go from there....Im not that technically inclined.
not trying to sell one, just turbo is an easietr wya of install and for the 34 to 38 swap...its really not worth it, the money you will spend to convert it will be about enuff to just get a 3800 car. so much has to be changed
ORIGINAL: MalibuMaxxSS
34, camaro, charger, engine, gm, impala, make, malibu, maxx, performance, super, supercharged, supercharger, turbo, work
