2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Ambient lighting disable
Old November 13th, 2014, 9:00 PM
Dmul98's Avatar
Default Ambient lighting disable
Can someone tell if there is a way do disable the ambient light strips in the interior on a 2103 or 2014 2LTZ? Thanks in advance.
Old November 13th, 2014, 10:03 PM
sledge.impy's Avatar
2013 has them?
Old November 13th, 2014, 10:18 PM
Impala-Blue-2.'s Avatar
The ambient light strips were only in the 2014-2015 Impala, not in the 2013 or 2014 Impala Limited. As far as I know there is no way to disable them, at lease there is nothing in the set up menus.
Tulsaguy (February 17th, 2020)
Old November 13th, 2014, 10:23 PM
Dmul98's Avatar
Default Meant to say 2014 or 2015
Meant to say 2014 or 2015. I wonder if there is a fuse that can be pulled?
Old November 13th, 2014, 11:14 PM
It's probably hooked into the whole instrument cluster that is on the dimmer switch.. so it's probably no separate.
What is your issue with it anyways?
Get some black electrical tape, get a knife, cut it, and put that over it or something.
I find the instrument cluster a little bright at night, so I use the dimmer switch. Never had a problem with the strips or interior door lights.
Old November 14th, 2014, 11:11 AM
Frank3's Avatar
sledge.impy, this sounds like a perfect time to crack open the service manual. Now, if there were only enough hours in the day to get all the stuff I want to get done.
Old November 18th, 2014, 2:40 PM
LarryFL's Avatar
What is it that is annoying you about the lights? IMHO, I think they did a great job. That and the pop-up screen.
Old November 20th, 2014, 10:49 PM
Frank3's Avatar
Well, according to the 2014 service manual, I looks like the accent lighting is powered directly off of the BCM with the opposite end of the accent lighting grounded. Doesn't look like it would be easy, may even cause a DTC if disconnected.
Old November 20th, 2014, 11:00 PM
Only 1 way to find out - start snipping.
Old November 21st, 2014, 10:54 AM
Frank3's Avatar
That's for sure, a switch would also do the trick.
viper8399
Traverse
July 2nd, 2014 9:22 AM
jiggsy
Silverado & Fullsize Pick-ups
11
June 27th, 2013 10:19 AM
ericnottelin
13
April 13th, 2011 9:05 AM
CPT_Purge
October 8th, 2008 10:54 PM
ln3178
Express & G-Series Vans
August 29th, 2008 4:16 PM
Quick Reply: Ambient lighting disable
