Ambient lighting disable
The ambient light strips were only in the 2014-2015 Impala, not in the 2013 or 2014 Impala Limited. As far as I know there is no way to disable them, at lease there is nothing in the set up menus.
Tulsaguy (February 17th, 2020)
What is your issue with it anyways?
Get some black electrical tape, get a knife, cut it, and put that over it or something.
I find the instrument cluster a little bright at night, so I use the dimmer switch. Never had a problem with the strips or interior door lights.
sledge.impy, this sounds like a perfect time to crack open the service manual. Now, if there were only enough hours in the day to get all the stuff I want to get done.
Well, according to the 2014 service manual, I looks like the accent lighting is powered directly off of the BCM with the opposite end of the accent lighting grounded. Doesn't look like it would be easy, may even cause a DTC if disconnected.
Only 1 way to find out - start snipping.
ericnottelin
Silverado & Fullsize Pick-ups
13
April 13th, 2011 9:05 AM
