annoying popping sound when accelerating from a stop,turn or brake -_-
I just purchased a used 2008 Chevy impala ls and it has a popping that is driving me insane! It pops once or twice when accelerating from a stop and then occasionally when I turn and almost always when I come to a stop. It sounds like it is coming from the front tires and I have had the strut and strut mounts on the right side replaced. I am so frustrated with this and just kinda curious if any one has any idea what it might be and is it going to be safe for me to drive it :/
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> charity,
This issue may be caused by the rear strut spring rubber isolator contacting the lower spring coil. This is just a suggestion, not a diagnosis. I encourage you to consult with a certified technician at your local dealer. They will be able to offer additional information after a physical inspection of the vehicle.
Please keep us posted.
Louis
GM Customer Service
Louis
GM Customer Service
have you checked your cv joints?? if they're ok check all the rubber mounts and bushings
x2 on the intermediate shaft, if you can feel a little pop in the steering wheel when turning, turning over bumps, hitting bumps or sometimes just turning theres a good chance its the intermediate steering shaft GM passenger cars have had TSBs on this issue forever, kinda makes ya wonder why they never found a good fix from the factory
MyrtletheTurtle
May 20th, 2014 2:24 AM
Shammok
Silverado & Fullsize Pick-ups
April 9th, 2014 11:30 AM
Torn Barb
March 12th, 2009 7:19 PM
