2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Battery was connected backwards.
Old September 25th, 2013, 12:34 PM
Oovmeister25's Avatar
Default Battery was connected backwards.
I have a 2001 impala with a 3.4. The person that I got it from replaced the battery but hooked it up backwards. Now when you turn on the key nothing works at all except for the check engine light comes on. When the key is turned off the A/C button light is on. Nothing else is working. I checked all of the fuses and replaced the ECM. No change. Please help. Thank you.
Old September 25th, 2013, 9:56 PM
Professional Mechanic
MDTAHOE's Avatar
That is the WOSRT thing that can happen to a car, it wreaks havoc. You could hook the battery up backwards and the damage can be different on every car. You will need to take it to a dealer (as much as I hate to say that) almost every module/ computer that can be destroyed must be programed when replaced. How did you replace the ECM? It has to be programed
Old September 26th, 2013, 12:00 PM
Well I simply bought a used one and installed it.
Old September 26th, 2013, 8:45 PM
MDTAHOE's Avatar
It is not likely that that would work as it must be programmed to your car
chevy47390
March 21st, 2015 3:23 AM
94burbin
February 20th, 2015 2:59 PM
Allstate
August 8th, 2013 1:09 PM
litlsuzzy
July 13th, 2012 2:28 PM
Shearwig
November 16th, 2006 11:18 PM
Quick Reply: Battery was connected backwards.
