Console Screen Flashes
Hi folks,
When I use the left steering wheel trigger buttons to change my favorite channels, the console screen (the one behind the steering wheel, if it's even called the console) flashes. Specifically, the word 'Favorites' flashes quickly when I press the button.
Does yours do this as well?
I'm driving the 2014 LTZ.
Thanks
Thanks
Hi folks,
Thanks
Thanks
Is this AM/FM/HD FM?
Or are you changing XM channels?
I notice that it takes a little too long to pull in my XM channels, so by the time I see/hear what's playing - it's already out of the favorites menu, then I have to "double tap" again to get back into favorites and then to the next channel. But I can't say I've noticed clicking the button when in XM and seeing favorites pop up.
Which channels are you using?
In my Favorites I have 1 FM and about 14 XM stations, and it happens when I switch between any of them. Do a test today. Just cycle through and look at the word 'Favorites' in the console. See if it flashes when you press the trigger, then press it again to move up or down to select the next/previous favorite.
It's called the DIC. (display information console or something).
I have a 2ltz with navigation.
Do I need to get a high speed camera to verify?
Update to this (in case someone else has this happen), there was an issue with the DIC. I guess the software version of my radio was out of date, or the DIC version was different than the radio version. I'm not sure, but either way, the dealer flashed the most up to date version and there's no longer a flicker.
Thanks for the update.
You joined here April 2014, so you've had your car over a year?
And it just started doing this? Or was this something you just recently noticed, etc?
Was was your build month/year.. (inside on frame rail inner between driver and rear door).
Bulldog9539@gmail.com
September 4th, 2011 1:54 AM
