Engine oil low
Engine oil low
Tail end of last year I i posted a problem I'm having with a low engine oil message I get on my information center--it was suggested to change oil level sensor which I did when I finally changed the oil but I'm still receiving the same message. Does anyone have another suggestion to try. Thanks
Is the oil level actually low? Is it a false message? If the oil level is ok and the message is still there and you changed the sensor then look at the wiring to the sensor to see if there any bad spots such as stripped insulation, etc.
cdcpedroso
February 11th, 2022 11:18 AM
larry_chip
April 24th, 2007 11:46 AM
