2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Old July 24th, 2015, 4:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Finally a cheap passlock fix!
Old July 12th, 2014, 8:17 PM
  #191
dominator16's Avatar
How can I send you my e-mail address
Old July 15th, 2014, 4:31 PM
  #192
rivestpup's Avatar
I need the instructions
Old July 15th, 2014, 6:22 PM
  #193
sledge.impy's Avatar
Does anyone really believe there are instructions?
IF there were - why aren't they posted here?
Think about it!
Old July 16th, 2014, 5:23 AM
  #194
mobileinstaller's Avatar
Think about it!
Mainly because mine is done up in an image and not sure how to post an image on here otherwise I would
Old July 16th, 2014, 5:33 AM
  #195
Default tell me if you guys can see the attachment
I tried to attach the image of how to bypass the passlock system let me know if you guys can see it
Attached Thumbnails Finally a cheap passlock fix!-passlock-2-bypass-diagram.jpg
Old July 22nd, 2014, 1:07 PM
  #196
fj1200russ's Avatar
Default pass lock ? 2002 impala
My 2002 impala dose the same thing,sceurity light comes on and car wont start for 10 min . will a resistor in the pass lock loop do the fix,or do I have to buy a new key cylinder
Old July 23rd, 2014, 5:24 AM
  #197
You wont need a new key cylinder the cylinder is not the issue with these it is the passlock switch on the back side of the switch and the resistor does the same thing the passlock switch does when you turn your key on. Thus bypassing the switch which is almost always what fails . The system is like the old passlock 1 systems that had the little black resistor built in the key. Just now it is built in a switch connected to the ignition switch instead of being in the key.
Old July 24th, 2014, 4:18 PM
  #198
I was having the problem with the car not starting for over a year now and I took the ignition apart and cleaned it with sand paper and the security light is no longer on and the car is starting fine. It had gott to the point where it was happening a least once a week and I was always worried that it was going to happen in an emergency situation one day but so far so good.
Old July 26th, 2014, 2:48 PM
  #199
MrBarnes's Avatar
Hey man I'm glad you got it fixed! Have a good day!
Old July 27th, 2014, 5:02 PM
  #200
siprecords's Avatar
could you please send me the diogram on how to by pass the the ignition or cylen so my car can crank, right now i have a universal started switch to start my car siprecords863@gmail.com
Quick Reply: Finally a cheap passlock fix!
