2000 Impala LS No Turn Signals
No turn signals at all. Did the drivers side above headlamp ground screw new. New hazard button switch, New turn signal arm switch with cruise control, New fuses for turn signal on drivers side fuse box, Hazard lights work perfect. All light bulbs are working. So why not the blinkers? Yes I know there is old threads similar, and none like this problem at all.
New key switch and the part with the plugin for security. Now all signals work but the passenger rear dont and the front blinks really fast... Security light stays on the dash. I have mo clue but Im in the hundreds now.
Raz75reb
September 19th, 2010 11:28 AM
