Ignition Recall Issue
I had my 2008 ignition switch fixed since it was on the recall list. I have never had any issues with starting it before but since the fix I have had issues. Sometimes- I would say one out of 20 times I try starting the car -I put the key in and turn the key and just the dash board lights light up. It doesn't start. I than take the key out and try again and it will work. Not a big issue now but am worried something down the road might get worse. The dealer said it is just a coincidence and not a fault on their end from the ignition switch fix. There has to be something they have done to have this start happening. Any ideas?
Welcome to the forum...
You need to get your vehicle back into the dealership that did the work...I would suggest you remove any excess keys or bling from your key chain prior to taking it in so they don't suggest that its your fault by having too much weight on it...
I will add the caveat that if it turns out to be something other then something directly related to the ignition switch they replaced, you may be responsible for the diagnostic fee but they should tell you that up front.
The dealer said over and over that it wasn't due to the switch fix. He did promise me that he wouldn't charge me for the diagnosis but said more than likely it wasn't on their end and I would have to pay it to get fixed if they found a problem. Pretty coincidental that it started acting up right after the fix.
https://chevroletforum.com/forum/imp...e2/#post288694
Official GM Rep
Please let us know how your dealership service visit turns out. If you would like for us to look more into this matter, please send your VIN, mileage, full contact information and dealership name via private message.
Amber N.
Chevrolet Customer Care
I brought the car in today for a oil change and ignition diagnosis. They would diagnosis the car but would charge me if it came back not on their end. I told them this all started happening right after the ignition recall fix and it was up to them to diagnosis. I bought the car from them and have had it serviced there many times before so I was hoping they would stand by the problem. It's too coincidental that this all started happening right after the "fix". And this was also after GM called them specifically in reference to my car.
They didn't find anything because they said if they thought after the diagnosis that it wasn't on their end than I would have to pay for the diagnosis. The least they could do is diagnosis it on their dime regardless of the outcome. This all started to happen the same day after the recall "fix". Never before. I shouldn't have to pay a dime. I'm not the only one on this forum who have had issues after the recall fix. Too bad GM doesn't stand behind problems they created.
CharlieMSU
December 16th, 2015 4:20 PM
2004MaxxLT
July 9th, 2014 10:32 PM
Chevrolet Forum News
February 21st, 2014 9:18 AM
