2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Impala antifreeze leak
Old July 7th, 2012, 1:14 PM
sunturtle's Avatar
Default Impala antifreeze leak
I'm sure this has been asked a thousand times but... Have a 03 Impala 3.8, have a antifreeze leak on the pass side. Originally thought the water pump cause its dripping on the oil filter and catches on the area under the pump and power steering. But all around the water pump looks dry with no coolant stains. Replaced the two plastic elbows off the block last year and they are dry. Cant see where the blank its coming from. Any ideas would be appreciated.
Old July 7th, 2012, 1:45 PM
kevinkpk's Avatar
Don't know. I would suggest buy or if you can, rent a pump. Remove radiator cap COLD, install the pump, and bring it up to 10-15 lbs, then check for any leaks.
Old July 7th, 2012, 6:09 PM
intake gaskets are common
Old July 7th, 2012, 6:34 PM
kevinkpk's Avatar
It's an external leak. I should add to what tech2, yes, it should however be visible.
Old July 8th, 2012, 3:30 PM
sunturtle's Avatar
Default s
Starting to think this is from the freeze plug. Its not anywhere near the top intake/head area. Seems to be coming from behind the power steering pump. Is there freeze plugs hidden there? are there only 4? Thanks for any help.
Old July 9th, 2012, 10:52 AM
sunturtle's Avatar
Looks like its coming again from the intake elbows I replaced last year. I bought the doorman ones. Are the Napa balkamp ones any better? Or GM? My gm dealer doesnt have any and would take a couple day to get them.
Peter Bistany
November 3rd, 2010 7:58 PM
Jakester
Silverado & Fullsize Pick-ups
May 13th, 2010 4:20 PM
capsnumber1
Express & G-Series Vans
October 2nd, 2009 8:59 AM
jorgie5150
January 27th, 2007 5:18 PM
kdeinv
December 31st, 2006 10:09 PM
Quick Reply: Impala antifreeze leak
