2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Impala miles, How many do you have? I am sitting at 180K
Old March 10th, 2012, 9:59 AM
  #31
Blackops's Avatar
2000 LS with 279xxx on the clock... going well
Old March 11th, 2012, 11:36 PM
  #32
66impala4dr's Avatar
Default 66 impala
i have 28,687 true miles got car from the first owner and his wife blew the stock 327 motor with 2 rods out the side.
Old March 14th, 2012, 2:08 PM
  #33
ViggiAm's Avatar
04 111k had it since 06 & haven't done anything but get the oil changed. About to get the tranny & radiator flushed. Any suggestions or things I should keep my eyes out for that may need replacing in the next year or so? Thanks!
Old March 15th, 2012, 9:00 AM
  #34
capucine's Avatar
Dont get your transmission flushed. Just change the oil and the transmission filter. It will not remove all the oil since the amount in the converter will not be flushed but for this small amount it will mix with the rest of the oil. Sometime a flush can bring you more problems. for your radiator I would just change the dexcool with new one. Giving a full flush can agravate the problem that the 3.4 engine have with the intake manifold gasket that could start a leak inside the engine if you have not went through this problem. There was a big recall regarding this matter.
Old March 27th, 2012, 9:09 AM
  #35
kdhag's Avatar
Default 2000 Impala
219,500 miles, and looking for another 100K
Old April 16th, 2012, 7:22 PM
  #36
ElEdwards's Avatar
Me, again My '03 is almost at 322,000 miles.
- ABS light is on - I found a wiring problem that I'll fix on my next day off.
- radio died so now I use an mp3 player.
- only on my 4th set of tires.
- I replaced the OEM rotors and pads with drilled/slotted rotors and ceramic pads in December of '09 and have had NO braking issues since. The OEM rotors seemed to warp about once a year.
- I replaced the thermostat (what a bear!) to solve a slight heating problem.
- it's time for the 4th set of plugs and wires
I still get around 32mpg (manually computed - not that little overhead computer) and I'll drive this car until it gives up
Old April 19th, 2012, 6:46 AM
  #37
capucine's Avatar
ElEdwards: you never had any issues with your transmission or the dexcool intake manifold leaking problems?
Old April 20th, 2012, 7:38 AM
  #38
ElEdwards's Avatar
No transmission problems. When I heard about the Dexcool intake manifold issues, I was proactive and had the gaskets replaced.
Old April 30th, 2012, 3:34 PM
  #39
ragtime1962's Avatar
Default 2001 198,000 and a 2010 68,000
I have replaced tires and brakes in both cars----only!
Old May 28th, 2012, 8:33 PM
  #40
Alexander Volk Mirvis's Avatar
Default I just bought a 2004 Chevy Impala 56k miles
After reading your guys posts, I feel really good about my car now. lol I guess I will have many good years with it. Especially when I will only use it on weekends. :-)
Quick Reply: Impala miles, How many do you have? I am sitting at 180K
