2014 Chevrolet Impala
Includes: Bel-air
Platform: B-body & W-body
Intermittent starting problems, 2002 Impala
Old January 19th, 2016, 12:03 PM
  #11
allmerob's Avatar
Yes it has been scan the fuel pump fuel filter has been replaced twice in 3 months it seems like the computer is not telling the injectors went to open it throws no codes and then out the blue it will throw a code about the transmission pressure plate or something the computer also tells me that my oil level is low which can not be correct because I just did an oil change personally I change the level sensor and it is a new engine harness
Old January 20th, 2016, 2:33 PM
  #12
Frank3's Avatar
If a new engine harness was put in, do you have any loose or missing grounds? You have an assortment of errors here.
Old January 20th, 2016, 2:37 PM
  #13
allmerob's Avatar
All grounds were checked three times so I just ordered a computer waiting on It to get here now to see if that sorts out the issue
Old March 2nd, 2016, 9:14 AM
  #14
emilio96's Avatar
Default 05 impala stalling issue fixed
I had a problem car stalled and wouldn't start I had no spark after probing wit a volt meter I found there was no power to the icm so i replaced it and the camsensor still no start until I started fiddling wit the harness it had a short so i replaced it car is running beter than i bought it
Old July 21st, 2016, 3:41 PM
  #15
Matt Rao's Avatar
Yes it has that part
GeoMers
May 5th, 2013 7:30 AM
Chuckus95
Avalanche
May 2nd, 2008 10:03 AM
donerightray
Silverado & Fullsize Pick-ups
November 1st, 2006 11:00 AM
ffarv
April 9th, 2006 1:52 PM
Quick Reply: Intermittent starting problems, 2002 Impala
