Low Tire Pressure message
Hey guys, wondering if anyone had some advice on this issue. I had low PSI and its now correct in all 4 tires, which is 30 psi according to the manual. I have an aftermarket radio, so I can't reset the message that way. I've tried the rediculous reset using the light switch and still nothing. I drive 30 miles to and from work every day which gives plenty of time to recalibrate. Any ideas?
Thanks,
Paul
Thanks,
Paul
RE: Low Tire Pressure message
Yeah, I tried that. After I made that first post, I went in the garage and tried pulling the fuse to the data link. That didn't work, so I disconnected the battery. That did work. So, if you can't get the message off and you have the correct PSI, just disconnect the battery.
allen2424
Silverado & Fullsize Pick-ups
11
October 9th, 2011 11:07 AM
