No crank 2006 impala
New battery & starter, same problem, starter clicks once, all pos $ neg connection appear clean and tight.indicator lights on dash do NOT light, after several attempts they light and I hear 1click in crank position. I also hear a clicking it middle of the dash this comes and goes, I'm suspecting a faulty ignition switch and or pass lock. Any suggestions would be greatly appreciated.
No start
Thanks for the suggestion, I've seen that too. I found the blend door actuators behind the glove box to be the cause. They continue to run draining the battery, I suspect that heater control is faulty. After fully charging the new battery, performing pass lock reset and unplugging the actuators the car is running now.
